  • 21 Vote(s) - 3.29 Average
Posting images on the new forum
The forum now has 'In house' image hosting, so that means no need for photobucket, postimage, flickr etc.
It also means that images won't disappear when a third party decides to change it's policies.
-Maximum file size is 4096 kilobytes
-If 2 images are to be posted, they must have different file names. This can be a common problem for Ipad users, and is due to the way that the Ipad stores it's images. A work around for this eventuality is included in the second post, below.
Once you have got to the reply screen below the typing box there is a blue header that says attachments.
1: Next to where it says new attachment click 'choose file' then select the picture you want and click open.  It will put the file name next to the choose file button
2: Now click the 'Add Attachment' button to the right hand side of the attachment box. It will take a moment to upload, once done the page will refresh and it will appear in the attachments box below the choose file button. There will also be 2 new buttons parallel 'remove' and 'Insert into post'.
3: Click 'Insert into post' (Again on the right hand side of the attachments box next to the file name in question). This will insert square brackets with attachment=number in your reply box. (NOTE: this step is important as it puts the picture in with the text rather than in a separate 'attachments' box", below the post)
This [attachment=number] image code will appear where you have the cursor at the time. Once you have the [attachment=number] you can copy and paste it anywhere in the post to make sure it appears where you want it, so do not worry if it is not in the right place first off.
4: Make sure the code is on a separate line to your typing or you will get a stray bit of text next to the picture making the text difficult to follow. Putting a clear line in between as below makes it quite clean.
[Image: attachment.php?thumbnail=56]
Now for the second image, simply repeat steps 1 and 2. You will note that there is now another file added to the attachment box below the first. Now repeat steps 3 & 4 ensuring you click the button parallel to the second file. You now have an [attachment=number+1] in your reply box.
Note: If you experience an error after attempting to upload your second image, then this is usually down to both files having the same name. Due to the way the Ipad stores its photos, this problem is particularly common for Ipad users. A 'workaround' is included in the post below.
[Image: attachment.php?thumbnail=57]
Repeat for further images.
[Image: attachment.php?thumbnail=58]
Click preview post to check how your post will appear. If all is well, scroll down and 'post thread'.
Users can try out posting images HERE
All the best, and happy posting.
Great stuff Timothy! Thank you.
Ipad Users.
As above, if you have 2 photos with the same name, the forum will produce an error on trying to upload the second. It is attempting to add two files of the same type, in the same folder, with the same name. On Ipad (at time of writing) there is not a built in function to change file names so the easiest way to add multiple photos is to put them in separate posts. So long as someone doesn't post in between, the forum will merge the posts (with a line in between).
Replicating the conditions with 2 files of same name. First completing the first post with the one. Note the line above to signify two merge posts.
[Image: attachment.php?thumbnail=131]
Now clicked 'new reply' again, and add the second.
[Image: attachment.php?thumbnail=132]
Multiple photos with same name with text in line.
Give it a go in the 'image test' thread HERE
Happy posting
(17-08-2017, 08:44 PM)Ruairidh Dunford Wrote: Great stuff Timothy!  Thank you.
Thank you Ruairidh.
Just have to thank all of the forum team for making it all possible.
The 'in house' hosting seems to be bringing out a lot of fantastic pictures already, and long may it continue.
