Forward headlights were fitted as standard for a period during 1926; one of the cars with forward headlights is a Gordon England Cup, but the others could all be new examples with the revised fitting. Certainly they are all small-radiator cars.
Car type: 1932/3 AH tourer
It would be wonderful if our resident 'Photoshopper' were able to enhance this, and thus let us look more closely at the cars - and their registration numbers...
I wonder if some owners moved the headlamps to increase road illumination and reduce bonnet illumination, particularly after the works had started producing cars with that arrangement. I understand that it was discontinued because the powers that be decided that the lamps should indicate the width of the car. There are still specified maximum dimensions between lamp centres and side of car in respect of side and rear lamp positions.
Memory is a bit vague on this but I have a feeling that the Austin 7 car club was a factory run affair and there were branches around the world if I am right. I am pretty sure I somewhere have a picture of a group assembled in NZ, I do need to check that though as the grey matter may be failing me.
