24-12-2017, 09:39 AM
(This post was last modified: 24-12-2017, 09:43 AM by trevorcharlesmorgan.)
I've had my Austin 7 Ruby based special off the road for a year or so whilst I sent the block to be re-bored and I also had all the head stud holes helicoiled. I finally got around to sparking it up and got it to run for around forty seconds, I stopped the engine as I needed to fill the cooling system before running it for longer. I filled the radiator with fresh water and antifreeze. I then turned it over and water came not dribbling but gushing out of the the exhaust, the same fresh water and antifreeze I'd put in a few moments ago. I was surprised by the volume of water that came out. I haven't taken the head off yet but it seams as tough the water did not get into combustion chambers as the water did not cause the engine to lock up whilst turning over. Any ideas?
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
Did you take the manifold studs out ? If so will need sealing. Head studs also need sealing in my opinion. Good luck
I've got the manifold on bolts rather than studs so yes got them all out when a removed the manifold, I'll have to get myself down to Halfords then to see if I can get some thread sealer. Thanks for your response.
It sounds to me like more than manifold studs. I think a leak from there would dribble not gush. Are you sure that the cylinder head gasket is tight?
Mostly useless instructions , ideally timed for two engine builds about to happen here
Bill G
Sadly my auto spell changed useful to “useless”
I really appreciate these notes and will follow them to the letter
Sorry!
Regards
Bill
