offset 19 inch austin inscripted wheel
Hello all,
I'm busy with renewing the spokes on my 19 inch wheels Austin Scripted wheels (closed center).
But I was to enthusiastic and forgot to measure the offset of the wheels.
Does anybody has the dimensions? Or be so kind to measure it?
With kind regards
Pieter
Hi Pieter
I think that the wheel centre and rim should lie flat ie. no offset.  However I have read somewhere that you can offset the rear wheels if you have clearance problems.
I’ve done this with the new special wheels but only 3/8”
Hello Howard,
Thank you for the quick response.
With kind regards
Pieter
When I did mine the rim and the hub were flat
