I check for the valves touching the head by putting the head on the engine with no gasket. I then crank the engine while holding the head down with my other hand. It the head moves then they're too close.
That's another way to do it Austin, and no risk of damage.
Holy s**t Dave, take care man!
I did offer to loan you mine!!!
My old, large and somewhat arthritic fingers made collets impossible, so pin located valves have been used for some time. The discussion of improvised cotter strangling equipment made me wonder about returning to cotter retained valves, sometimes thought to be more reliable. Then I reached the last few comments above, so let's stick to the pins!
It’s toe curling stuff Steve - still wincing!
I have had similar accidents involving power tools, although not, fortunately, with the consequences of your own mishap, Dave.
You have my heartfelt sympathy and I hope it heals quickly.
Ouch. Hope you heal quickly. Angle grinders are very dangerous tools and need treating with healthy respect. And yes, I have a scar too!
Dave, when you say a 'sports' block, is it a standard block which has been ported or an original Austin sports chromidium type? If the latter, frankly I wouldn't run it on a Ruby, and certainly not with an LC head. I only fitted an LC head once but struggled to get my Nippy over 40mph with it (normally capable of 60+)
As others have said, double springs are only of real interest for a sports car, singles limit your revs to perhaps 4500 or 5000 rpm. I always understood the principle is that the springs resonate at different frequencies so at least one will be doing its job at any given moment. I use double springs myself, but then I have a 'bottom end' which is set up to take the rpm.
