02-04-2019, 12:22 PM
Gentlemen,
Something to exercise your little grey cells!
My 1932 RN is fitted with late Girling axles front and rear and a 4-speed box with Hardy Spicer propshaft.
Lately I have noticed a strange noise from under the car that seems to only occur when the engine is pulling hard, say up a hill, often in 3rd gear. It sounds like a muffled dull knock, as if the floor is being struck with a hammer from underneath.
It doesn't always happen, but when it does the timing between the sounds can be one second or as much as five seconds. I usually back off when it occurs because I don't know what it is nor what damage may be caused. The car otherwise drives normally although the CWP sings at 30 - 40 mph on light throttle only, never on the overrun or accelerating.
The gearbox and rear axle have been rebuilt with all new bearings.
I think the propshaft and joints are OK, but I haven't pulled anything apart yet.
Your collective thoughts will be greatly appreciated. Thank you!
