As far as matching ports goes, I feel that if the manifold inlet ports are not blanked at all by the block there is little to be gained by removing metal, and like wise in the exhaust ports try to be sure that the manifold does not blank the block exhaust ports. You will get smoother gas flow by having the ports exactly matched and polished, but it is a diminishing returns situation in relation to effort.
I removed the manifold, ground out the "restriction", and replaced it.
No improvement at all.
But: there may be other factors affecting the result, I'm afraid. I subsequently found that the engine is fitted with particularly wicked oil control rings, such that there is quite a lot of resistance to up and down movement of the pistons.
Which may have masked any change made by opening out the manifold. Which may also be the reason that my raised compression early head made not a lot of difference, either.
Simon
Hi JonE,
I've done a couple of these, one being a Reliant downdraught type. The only extra thing I did was to hacksaw down to the manifold stud holes either side of the inlet ports. I did hear a while back that on flow testing, the restriction in the cross over part of the side valve engine was such that the other parts, including the eye in the inlet flange, didn't cause any ill effect. Matching ports has little effect on oversized ports like the A7. If you want to do something just make sure the downstream side - the block port - is slightly tapered so that any square edge at the join is on the upstream side rather than facing into the airflow.
Hope of use, Dave
Car type:
Dave - the first bit presumably to further reduce the percolation of warmth into the aircharge-stream walls?
I've ordered another pack of ebay Hong Kong grindstones...!
HI All,
Has any one done a proper test on the blended Fuel that is used in the UK, To ascertain if it is at all necessary to remove the hot spot , the seven is not the only engine with this feature .
and as Paul points out it will only work till the Whole manifold heats up.
Colin
NZ
Hi Slack Alice
It is an aside but when I was running my car as everyday transport eons ago the neighbours sons worked with Lester Reeder on specials iand on his Rubber Duck. They had all run Sevens and were adamant that the steel 4 piece type oil rings killed performance. They reckoned Sevens only went best when worn out!
