does anyone out there have a rear window frame for a pearl cabriolet available for sale,I have just acquired a very original but "scruffy"! car running and driving plus as a bonus it stops very well .There is no rot anywhere and the original interior is very usable and will be preserved it has had a new hood at sometime and I think that was when it lost its window. could any owner of a pearl post the size of the frame and the height it sits from the top of the body best regards Rob.
Is it a mk1 or mk2 Robert?
its 1936 mk1 best regards Rob.
I will measure mine later for you Rob, I think it will be easy to shorten a Ruby glass to the correct dimensions.
Does he not mean the rear window not the side ones?
yes your right I meant the frame in the hood, thanks to all Rob.
09-07-2018, 11:47 AM
(This post was last modified: 09-07-2018, 11:53 AM by Nigel was in Brittany.)
Is a Mk2 window the same size as a Mk1, if so I have the rear glass out of mine somewhere.
If its any help I have the rear outer frame on the shelf in the garage, would it help you if I draw round it on paper ? Edit to add : mine is a MK2 but presume they are the same.
