Hi Mark, excellent pictures, thank you! How did you make the pop off valve on the end of the inlet manifold?
Simon
8200 rpm - holy s**t!!!
You do things very well Mark!
Impressive work, Mark! Thank you for posting.
Erich in Seattle
Fantastic project and a beautiful looking engine! Willing to share it's spec? John
Hi Mark
Sounds as if it could be a lot, lot faster
than the original? Is this car for circuit racing
Or Sprints? Or Roadgoing!!!?
Bill G
Bill, you are probably correct but remember it is extremely unlikely that the engine will achieve those rev's when in the car and under load. if it did we would be looking at something over 120mph. Mark will correct me if I am wrong, but as I recall the factory struggled to get enough power to push the car much over 95mph, however Mark may well achieve the magic Ton which eluded the factory for so long.
That handiwork too good to damage.
5 squared is 25, 8.2 squared is 67! A 170% increase. What rpm was the original held to? The owners of the NZ Rubber Duck never managed to put the original crankcase back together again successfully.
Have you made any mods to ensure the block stays attached to the crankcase?
