Whilst at Moreton Marsh for the centenary, I experienced the same problem. High Compression Ruby cylinder head. Noise from the front of the engine, no loss of power. My initial thoughts were blown exhaust down pipe gasket. placing my hand near the front of the exhaust manifold, revealed the leak was from the front of the cylinder head/block. Removal of the cylinder head revealed the head gasket had blown away completely between the two front head studs, but was still sealing around the cylinder bores and water jackets. replaced the head gasket. problem cured. I now do regular checks on the tightness of the two front head studs/water outlet.
John
Quick update. I had decided to bite the bullet and take the engine out to make removing the manifolds easier as I was anticipating problems removing the fixing bolts which had been used instead of studs.
Before actually removing the engine I thought I'd try soaking the bolts with penetrating oil and see if they would undo. Using a short ring spanner on the most accessible bolt I gave it a few taps with the mallet before trying to undo it. I thought it was going OK but then the bolt suddenly sheared.
I now have a compression tester which revealed Cylinder 1 was 75 psi, Cylinder 2 was 85 psi and Cylinders 3 and 4 both 90 psi which makes me wonder about my initial thoughts of a leaking inlet valve.
So I now have the engine under my hoist and was intending to first loosen the cylinder head nuts so that I could potentially still turn the engine over on the starter to help release the head. I was then intending to remove the engine and try to remove the manifolds before taking out and re-grinding the valves.
My main worries are that it seems likely most of the manifold bolts will probably shear unless I can think of a better way to release them. If they do shear how practical is it to drill out the remaining thread with a hand held drill?
Secondly, am I likely to have similar problems with the head studs bearing in mind the head hasn't been off for over 30 years?
Lastly, I don't like stripping the engine when I don't really know what's wrong.
John.
27-05-2025, 05:01 PM
(This post was last modified: 27-05-2025, 05:02 PM by Charles P.)
The head might be resistant to movement.
I usually lift the head by screwing in two spark plugs adapted to be lifting eyes. I then apply Plus Gas and then lift the car using these plugs, remove head nuts and leave it overnight. The head lifts.
Since you’ve already removed the engine I’d do it anyway and next morning whack the head studs with a hefty copper hammer.
Charles
When a cylinder head is difficult to remove I have found that a hefty tyre lever under the hexagon of a sparking plug and using a nearby head stud as a fulcrum will normally get things started. You may need to do this at a number of positions, but once it starts moving it gets easier. Plus Gas helps to loosen things, particularly after you have some movement.
The 'Indian Rope Trick' is useful in loosening cylinder heads. With the piston at the bottom of the cylinder, feed a length of thick cord or thin rope into the bore through the spark plug hole (easier if the plug is immediately over the bore). When you can get no more rope in, give the starting handle a turn. It will be stiff but you aren't going to do any damage. This is often just enough to loosen the cylinder head.
There are several points to answer there John...
Firstly, I generally remove the head before lifting out the engine, as well as the major accessories such as starter and dynamo. It's a lot less weight to lift, and fewer things to foul.
Your compression figures do suggest that investigation may be needed. It's the variation that is cause for query.
The head MAY be difficult to remove, or it may not - try it. Mine usually comes off without much bother. You may then be able to see a few more pieces in the puzzle e.g. state of head gasket and (possibly) if you have a burned, sticky or mal-adjusted valve. Ref your comment about 'reluctance to strip an engine without knowing what's wrong' - go for the easy hits first.
Don't smack your manifold studs/ bolts with hammers. These threads are 'delicate' on most blocks I've encountered.
If you have to drill out a stud or bolt, give it your 'A-game'. Wobbling around hopefully with hand drills is likely to end in tears. If at all possible use a jig to guide & centre your drill. Better still get a machine shop to do it perfectly on a pillar drill (though in this instance that would entail stripping back to a bare block). Those among us who are well practiced at this sort of stuff will doubtless reply they can do it by eye - just as some among us can plaster a ceiling without any bother...
Why are you contemplating removing the head studs? I would not attempt this unless I absolutely had to. You will almost certainly break at least half of them. The only real reasons I can think of to remove head studs is if they are damaged or if you need to skim the top face of the block. Removing the nuts should not be problematic, though occasionally you may find a loose stud comes up with the nut.
Best of luck.
28-05-2025, 11:51 AM
(This post was last modified: 28-05-2025, 11:52 AM by Steve Jones.)
Many (probably over 30) years ago I made up the cyiinder head drill guides and manifold stud drilling jig described in Woodrow (Pages A5-11 and A5-12 in my copy). I've used these ever since for drilling out broken studs and have always had 100% success. Not something you use every day but one of the best things you've ever made and simple to use when you need to use them. However, heating a stud at the base to dull red, letting it cool slightly and then using a proper full length stud extractor often means even the most stuck stud usually screws out.
