Lucas AT 201
Hi All,
I'm looking for a spare bit for my AT 201 tail lamps. The bit I need is the connector for the wires which has the spring loaded contacts for the bulb at the other end. One of mine has stripped threads for the clamping screw. Is there a source for these? Mine appear to be newer than the 201 body and other parts. I would have thought the Complete Automobilist would have them but they don't show them in their catalogue.
Erich in Mukilteo
Would one of these provide a source of parts, or are they different? https://www.s-v-c.co.uk/products/288-con...-type-l582
Les, Having compared these to the 201s, I think the connector is similar but the 201 connector is shorter.
Someone must have some of these kicking around. I know the 201s are bit more rare.
Erich in Mukilteo
(28-05-2025, 01:31 AM)Erich Wrote: Les, Having compared these to the 201s, I think the connector is similar but the 201 connector is shorter.
Erich in Mukilteo
Erich,
The nearest to a Lucas AT201 is this- you can remove the plastic insert and lens and replace with the originals - I have done this twice and they look like the originals
288A: Rear lamp equivalent to Lucas L582 model with glass prismatic lens - Indicators - Lamps - Classic Car Parts | Complete Automobilist
Not cheap but at least they work
Keep looking, Erich; they were certainly available in the 1980s, I repaired a number of AT201s using new connectors. If someone was supplying them now, then surely they are still going to be available?
Something like this?
https://www.classicbulbs.co.uk/products/...rt-ba15d-1
I think this is what you're looking for:
.jpg   bgw__253-con-1.jpg (Size: 93.42 KB / Downloads: 134)
https://www.classicbulbs.co.uk/products/...bulbholder
Robert, that's exactly what I need. Thank you. I'll place an order today.
Erich in Mukilteo
