25-05-2025, 08:46 AM
Hi All
My van has a forward facing (in cab) starter motor that turns well and cranks the engine smartly at 6.4 Volts. However it will only do that if the starter pinion return spring is so loose as to be ineffective. If I tighten this spring up to hold the pinion it simply won’t fire forward.
The problem I hear you ask….with a loose spring the pinion rattles like a snake!
I have an earth return direct to the battery and as mentioned the starter turns the engine well so I don’t think this is due to a lack of electric power.
Anyone had the same problem?
