MK2 Ruby: Very high compression pressure
My Ruby engine was rebuilt about 2000 miles ago (not by me) and is +60 with HC head. It runs OK but sounds harsh particularly when climbing. It rapidly runs out of steam on hills and will not exceed 45mph on the flat.  Timing is correct, auto advance functions correctly and brakes are not binding.
I carried out a compression test fully expecting to find unbalanced pressure or maybe some leaky valves. I was surprised and initially delighted  to find all 4 cylinders gave 150psi, but now am not so sure. Does this pressure indicate a (too) high compression ratio. Could this be the cause of the harsh running and lack of performance and if lowering the CR could rectify this, how should I go about it: Are thicker gaskets available?
I would be grateful for any thoughts, experience and advice on this.
Thanks
Ian
Are you sure that the auto advance is working?
Hi
The overbore will have increased the CR by maybe 5%, i.e. not much.
Compression gauges are probably only accurate to +/- 5% so might be slighly over reading.
The head may have been skimmed, which will also up the CR. You could measure this externally.
In the old days a severe build up of carbon would have been a reason, but with modern fuel and oil it's less likely
I am not aware of any thicker head gasket options. In desperation you could try using two standard HC gaskets but it will reduce heat flow from the head.
However, I wouldn't immediately think that a raised CR would lead to a serious drop in performance. Is the exhaust free flowing, i.e. not choked up ?
As Austin said, I'd definitely double-check the ignition. How did you set the timing?
Is it on the standard Zenith carb?
A Ruby ought to be able to pull 50mph on the flat.
The HC head is a sound choice but people will skim more and more metal off them - the only way to really be sure is to measure it. Personally I wouldn't recommend a CR above 6.5 or so for a road car (as advised by Bill Williams many yonks ago). In my feckless youth I tried various heads with CR up to about 10:1 and they certainly make the car noisier; some went fast and some didn't.
(16-05-2025, 09:22 AM)Chris KC Wrote: A Ruby ought to be able to pull 50mph on the flat.
My early Ruby with low compression head and 2 bearing engine manages 49 on the flat, eventually. That's a genuine Sat Nav 49. It's awfully noisy though and much happier at 40 or less.
Timing was set by determining TDC via chopstick in No1 plughole (repeated several times and marked with felt tipped pen).
TDC was marked on camshaft pulley and a pointer was fastened to bolt on crankcase to right of pulley. Advance mechanism was visually checked and looked perfect, though there was very limited movement, it was max possible prior to weights touching dist body at full forced advance, but looked to be as designed.
 Points were set to just opening at TDC using 6v bulb connected to distributor wire and earth. Engine was started and timing was advaned minimally to obtain smooth running and using strobe timing light it was observed that spark occured  about 1/8" before  TDC on slow tickover and advanced about 1cm (3/8") at high revs. It would not advance beyond this.
In light of comments, this was all repeated recently, this time setting timing exactly on TDC at very slow tickover.
There appears to be no improvement in pulling power, top speed or harshness. Though I did find I had a loose fan pulley, which when tightened has solved a mystery rattle. Wheels were checked and not binding, Exhaust has no dents and as far as I can tell is free flowing.
Any further suggestions gratefully received,
I would try taking the car out on the road and manually advancing the distributor by hand via the adjuster plate until the engine feels harsh, and then backing off a little. It may well be that the engine is still running retarded. On my RP when I fitted a 37 head it went like stink but I had to back it off a bit to prevent it from self-destructing.
If you are using a strobe with an adjustable advance knob, it's dead easy to have it set wrong. I use mine on a modern lotus where I set the advance and the tdc and crank pulley line up in the strobe. If I forget to zero it after and use it on something else, I end up wondering why the timings so far out.
Using on the A7 I have a paint mark on the flywheel at fully advanced and a hole drilled in the flywheel cover . I still sometimes check the timings but then realise I haven't set the strobe to zero.
A pressure of 150 psi does seem high - that's about 10:1?  Have you measured the thickness of the head?  I think it starts off at 1".
How much has to be taken off to increase a standard bore engine to 10:1?  Does anyone run their car at this compression ratio?  Mine is at 7:1 (calculated, not measured) which seems plenty high enough.  is there a possibility of valve seat recession at 10:1, I wonder?
In case it helps, 1/8 inch at the rim of the camshaft pulley equates to 7 crank degrees.
The Ruby auto-advance distrubutor had an advance range of 16 crank degrees (8 distributor degrees) when new.
Given the wear in components and the changes to fuel over nearly 90 years, plus any engine modifications, trial and error is now the best way to determine the ideal timing.
Unmodified heads were about 1.5 inches deep, info from the Bristol club here: https://www.ba7c.org/technicalArticles/c...atios.html
