Bulb type…
Can anyone tell me the bulb type/code for these please?
6v 21/5w twin filament parallel pins
Thank you.
I think that's 15D, the 15 being the diameter in mm. But please wait for others
Hi
I think that's a BA15d base. The staggered ones are BAY15d
https://www.classicbulbs.co.uk/products/...bulb-b383b
Please double check, it's a bit of a minefield !
I was just about to add that having done a bit of searching and agree BA are parallel pins and BAY offset
Thank you, John and Andy - very helpful indeed.
Ruairidh
I suspect its 25/25 Watt headlight bulb. As mentioned already its 15d bayonet fitting.
It's a slightly unusual bulb in that the pins are parallel. Most stop/tail bulbs have offset pins, so the bulb will fit in one direction, allowing the correct tail-light and stop-light contacts to be made. The earth return is through the body of the bulb.
Some single-filament bulbs have a double base contact, one for the live feed, the other for the earth.
One of the problems in ordering bulbs is that the sellers often miss out important information or put up useless pictures. e.g this retailer, while this one has all the data correct
I had a similar problem when I replaced my rear lamps for the pattern L582 type lamps. The lampholders were for for parallel pin type bulbs and all I had in stock were offset pin bulbs. Got over the problem by filing the upper pin off.
Hi Rory, yesterday I was also trying to find some 5/21 W bulbs with parrallel pins, can't find any suppliers so if you do could you let me know, I'll do likewise if I find any!
See John Cornforth's reply, above, Gerry.
