07-05-2025, 09:21 PM
I'm in the process of restoring my 1929 fabric bodied RK saloon.
The Car is completely in pieces.
I'm trying to get the rear axle back onto the rear springs to ultimately get the chassis back on its wheels.
I'm having the dickens of a job trying to get the rear spring pins in.
I tried fitting the springs to the axle out of the chassis. That worked and the spring pins and cotters fitted, but, because of the toe in in the springs I couldnt get them to slide into the chassis.
I tried fitting the springs to the chassis first, I left it all loose with plenty of wiggle room. I have the rear axle roughly in the right place but I just can get it lined up sufficiently to slide in the spring pins. Can anyone offer some advice as to how to go about doing it?
