Gudgeon Pin bolt
Hello all, has anyone built up an engine and just used thread lock on the gudgeon pin bolts to keep them secure and tight. If so have you had any problems. In the past I have used it but not been brave enough to leave out the locking tabs.  All views on this will be appreciated
Joh Mason.
I have never used the lock washers, always thread lock and a spring washer.
I don’t use tab washers, either. Just thread lock and a spring washer.
Thank you both. You have given me the confidence to go ahead and dispense with lock washers.
John Mason.
I never use the lockwashers just a new spring washer, never had trouble in that dept Smile
