fuel gauge
I'm still working on the tourer, the brakes now stop the car the dynamo charges but I'm stuck with the fuel gauge which is not the original, there are no markings on the gauge as to which terminal is the supply and which goes to the sender. anybody any ideas?
Try it with a couple of AA cells, watch which way the needle moves - I think they are crude instruments that shouldn't be bothered by a bit of low voltage reverse polarity.
I don't know whether you might find this of help, Dave?
https://www.austin7.org/TechnicalArticle...rking.html
I know there are two different guages used on Sevens, each wired differently. If the wrong guage is used then it reads backwards ie says empty when it's full and vice versa. Just swapping the wires doesn't fix it.
This Fuel Gauge is not reliant on electricity Big Grin
.jpg   Chummy Fuel Gauge.jpg (Size: 69.04 KB / Downloads: 242)
Yes Tony I have similar ones for our cars, I much prefer front tank cars they are much easier to work on. I suspect the one I'm confronted with is the later type.
Hi Dave
Any chance you could post a pic of the face and back of this "non original" gauge ? I might be able to help further given this info.
Hi John here are the photos          . I suspect it is a later type because it has a resistance of 60 ohms between terminals and infinity between terminals and the case.
I think the earlier one was calibrated in gallons.
I may be wrong, but I think also it was labelled as Petrol, not Fuel.
