Bracing Front Axle on Ruby
I have read a number of posts explaining how attaching a tie rod from the king pin area back to the radius arm can help to improve braking by reducing the tendency for the front axle to twist. My front axle is a bog standard Mk1 Ruby axle. However, I have not found any clear information on how the rod is attached to the front axle, other than on cars with the later Girling axle or on specials with all manner of modifications.
Does anyone have any photographs of such an arrangement or can they direct to me further information, please?
Jamie.
Hi Jamie,
I have seen braces taken from the top thread of the kingpin to part way back along the radius arm.
Thank you, Dickie. That is helpful.
Does anyone know what the thread is in top of the kingpin? I could then fabricate something.
Jamie
I wouldn't have thought the plug thread would be strong enough- and remember the connection has to rurn.
I seem to recall someone drilling a hole in the axle in the hollow region near where the spring shacklepin fits. Is this common or my imagination?
Do all Rubys have the double bolt connection on the heavier arms ?  Wasn't this supposed to stop rotation under braking.
Tony.
See the following post low down the page (you might already have found it) : https://www.austinsevenfriends.co.uk/for...p?tid=3342
