13-02-2025, 04:09 PM
I have finally got around to doing this job which I posted a thread about last Summer - Ruairidh has given me much advise offline and this has moved me forward some what.
In the thread last Summer Ruairidh and others mentioned that the brake levers on the Girling front brakes were too far back - and the thought was that the front brake cams were the wrong side. Unfortunately they are not, which would have been easy to put right. The near-side cam has a very faint marking which I think is FN, but the off-side cam is very clearly marked FO which I assume is Front Offside. Back to the drawing board. The shoes will be relined and everything refurbed, but how to assemble with levers further forward???? I haven't taken the cams fully apart yet.
It was suggested that the shorter Austin arms could be used but would these require Austin cams - I assume they would as I note the cotters are different.
I am reinstalling the old "open" bearings as there is nothing wrong with them, together with a modern lip-seal. Just packing the bearing with grease and little more to avoid contamination again. If I had replaced the bearings I would probably have gone for sealed to get around the problem. How much grease is too much !!!!!!!!
Has anyone got advice on the best grease to use given the need for it to stay there for a while. Well the rest of my life anyway!!!!
I have seen descriptions of two ways to remount the hubs.
1. Build the inner hub and bearings with spacer on the stub-axle tightening the hub nut and apply the split-pin. Then pressing (well hide-faced mallet) the outer hub (and maybe the puller to add weight) over the top and screwing the two hub halves together.
OR
2. Build the hub entirely and screwing together before installing over the stub-axle. Apply the nut and tighten adding the split-pin through the holes in the threaded section of the outer hub.
A paper gasket and seal cement being used in either method.
Any help gratefully received as always.
Supplementary advice required please -
I use a lithium grease cartridge (Witham Oils) in the usual style of gun for regular greasing. This often drips from the gun as "oil" - of course grease has an oil base but is this a common happening. My old Mini grease gun never dripped in this way??!!
OR
![[Image: 20250214-135811.jpg]](https://i.postimg.cc/wBDZQybt/20250214-135811.jpg)
![[Image: 20250214-135759.jpg]](https://i.postimg.cc/DZ9WkNPp/20250214-135759.jpg)
