Just before Christmas I took my block into have it bored from 20 thou to 30 thou as I needed to replace the pistons to get rid of the little end knock and I managed to get some new old stock 30 thou pistons.
I have spoken this morning to the engine reconditioned who tell me that the block hasn’t cleaned up at 30 thou - apparently the borer (as the engineer put it) didn’t touch the topic the bore. He recommends. Either 40 thou pistons or another block that isn’t out to 30 thou already.
Has anyone got such a lock that they would be prepared to part with, or alternatively a set of decent 40 thou pistons?
I have some +60 pistons and a block to go with them if that helps - near Pwllheli
06-01-2025, 01:15 PM
(This post was last modified: 06-01-2025, 01:16 PM by Charles P.)
Depends what it'll clean to.
If you buy some of Tony Betts' pistons they are in metric sizes, so 56.75 is 34 thou over, and 57.00 is 44 thou over.
I'd sell the +30 pistons and buy new ones or take daveg up on his offer
Thank you for your replies, gentlemen. Dave got, I have pm’d you regarding your offer.
Charles, I have rung Tony and left a message for him regarding a set of pistons.
We shall see what happens.
If I was doing another block I would go for a set of Tony Betts slipper pistons.
The engine I'm using now has Honda pistons but I'm not altogether happy with it.
The original engine for the car is now back together with new rear main bearing and much better timing gears from Tony Leslie.
Probably the best solution. Should only take a day to do.
Hi David
+1 for Tony’s slipper pistons!
+2 & +3 for Tony's slipper pistons
Aye
Greig
Thank you for all the contributions to this thread. I would love to have a set of Tony Betts' pistons, but, having spend over £1000 on the Landrover this past year, the car fund is looking a bit sick, so I shall have to save up!
In the meantime, young Leon found a decent block advertised on Facebook that I have bought and delivered to the engine reconditioners and hope to collect it next week.
Changing the block means that I shall have to get a number of bits and pieces, such as new studs, but I am in no rush as, this weather, the garage is not a place that i wish to frequent at present.
I am aiming to get the little car back together by April, but updates will be provided as progress continues.
