17-05-2018, 09:32 PM
I think the 1" is the OM...
H1 SU versus Ruby Zenith sidedraft
17-05-2018, 09:39 PM
The carbs carry little or no designation so the type is a mystery to most . I am not sure but understand the H alone is 1 inch., the diameter at the output. H2 is 1 2/8. Earlier without oil dashpot were OM etc but I dunno the exact distinctions.
Some early had horizontal mount holes and fitted directly.
18-05-2018, 05:27 AM
For what it's worth we fitted a 1 1/8" to Dad's 1930 Triumph Super 7 in place of the old updraft Zenith and it made a world of difference. The car is now useable in modem traffic, much more get-up-and-go.
In fairness the Zenith was pretty worn, so I modified a damaged spare updraft manifold with a flange to take the side draught SU, the original manifold and Zenith is in the Triumph spares for the next custodian after I pop my clogs Car starts on the button, is smooth and progressive right throughout the rev range and the pick up in power is markedly improved. It runs a high ratio diff and close ratio 3 speed box, so pull away was always a fiddle with the Zenith. It's a joy to drive and we are no longer a mobile chicane on the roads. We run a pair of 1 1/8" SU's on the A7 race car with a balance pipe between them, engine reeves freely to 6 grand where I chicken out. I'm a big fan of SU's despite all my Alfa's running either Webers or Solexes Aye Greig
20-05-2018, 07:38 AM
(17-05-2018, 04:51 PM)JonE Wrote:(17-05-2018, 12:09 PM)Chris KC Wrote: For me the big advantage of an SU is once set up you can forget about it. Mine came from a jumble sale for £1, was cleaned up with paraffin and went on the car. Thus I must say £250 sounds an awful lot to me.Chris, I'm happy to pay a quid commission too if you manage to find another one.... I picked up a 1 1/4" HS2 at Beaulieu yesterday - it's old enough to have a brass dashpot top and needs a bath in WD40, but recoverable I think. Together with a 4-speed A7 gearbox top / gear lever set me back £15. Inflation!
21-05-2018, 11:34 AM
There are two 1" SU types commonly available, the OM, which has a round air intake and no intake flange and the UBA, which has an intake flange suitable for an air filter. UBA's have a vertical mounting arrangement, so need an adapter to mount onto an A7 manifold. They were standard on late Morris Minor and early Morris 8 models but may have been fitted to other, less common vehicles.
OM's are more variable and some have a horizontal mounting and bolt directly onto an A7 manifold. Fitting an SU to an early car is a bit of a challenge, requiring a special inlet manifold. I have a UBA on my mag engine Chummy, using a manifold fabricated from 28mm plumbing fittings! It just about allows the SU to fit in and close the bonnet. However, I have obtained a Derrington aluminium manifold, which gains about an inch over my creation. Sadly, it is cracked and probably only suitable as a pattern. I may see about getting some reproductions cast.........
21-05-2018, 12:29 PM
F4B20BB9-1B31-415C-88E7-5E5AE31485FB.jpeg (Size: 143.4 KB / Downloads: 154) Just picked up an OM in good nick on E-xxx For £25, very neat fit on a Ruby manifold. There was another one for £35 listed No adapter needed with this version. Seems AN is the needle to go for? I have a steel crank, slipper pistons, But so far am planning to use standard Cam and followers. Any practical advice appreciated As I’ve never built an Austin 7 engine before. It’s an 1 1/8” two bearing coil engine. Bill G
21-05-2018, 12:45 PM
is it still there, Bill? trying to find these things is all down to what words one searches on!
21-05-2018, 01:11 PM
AN needle is what I use. I have also dabbled with a GG..
AN is a good place to start...
21-05-2018, 01:17 PM
(This post was last modified: 21-05-2018, 01:18 PM by AllAlloyCup.)
Hi JonE
There’s another on E-.... for £169 or offer just now but it has the flanges that need an adaptor and an aircleaner Add Classic to the search terms I gave you, Bill Hi High thanks for the needle tip:-) Bill G
21-05-2018, 01:20 PM
Adaptors to the inlet manifold used to be available from usual sources but if not they are easily enough fabricated. Wouldn't worry too much about the air cleaner.
