Car type: Austin Ruby
After engine rebuild refit etc the Ruby MK 2 is now starting and idling quite well. Problem we seem to have now is coolant leaking from a number of manifold stud brass nuts. The manifold itself does not seem to be leaking any exhaust gases or fuel.
Are there any well used fixes?
We were thinking of undoing one nut at a time and getting some blue hylomar in there before refitting washer and nut or is it best to tackle this at the cylinder head end and remove the manifold completely?
The leaks come from the threads of the manifold studs where they're screwed into the engine block as some of the drillings penetrate into the coolant gallery. The best, and usually permanent fix is to take the manifold off and then remove the offending stud and refit using some loctite. That is somewhat simplistic because often you will either shear off a stud or damage it trying to extract it. Better to be forearmed with some new replacements before tacking the job.
Hi
Not the best practice, but I’ve just removed the nuts, smeared Threebond on the threads and washer, tightened back up. These kind of leaks tend to heal after a while (there is always the exception to the rule!)
I took nuts off one-at-a-time and wrapped PTFE tape around, then put nuts back on. (better not mention the k-seal as not everyone is happy with it).
Seal the studs in the block if water gets drawn into the inlet ports it will damage the pistons. Terry.
09-09-2024, 06:45 PM
(This post was last modified: 09-09-2024, 11:36 PM by Steve Jones.)
I always fit manifold and block studs with a turn or two of PTFE tape as a matter of course. Just make sure you wind it on such that it doesn't unwind when you fit the studs
Radweld, in the short term?
Every time I have had my engine seriously to bits, I have always ended up with a small coolant leak. A bottle of K-seal works wonders!
Live in a hard water area.
A fill with of tap water tends to seal minor weeps, but I do put them in with loctite to be safe.
