31-03-2025, 12:38 PM
Any useful tests for a loose little end? I've got a regular tapping under load, which disappears when you lift off.
Little End Tap
31-03-2025, 12:44 PM
I think little ends usually rattle as the revs are falling.
Press the the throttle and raise the revs then let it go. As the revs fall loose little end rattle.
31-03-2025, 01:47 PM
Little ends tend to tick on tickover.
