04-11-2021, 05:11 PM
I was playing around yesterday with charging rate/running using a replacement 3ohm resistor for summer charge.
Even with third brush adjustment, it is all too easy to get 'not quite enough' or 'too much' charge using the single resistance, just to return a tiny net positive when pootling along.
Morris used the CFR2 two resistances to make a difference between Winter and lighting settings, by splitting F1 from F2 as the cutout allows (but Austin never used).
Has anyone tried it and if so, what resistances did you find suited your running?
