crankcase ser. number for Bantam Turbo
my crankcase number M283378, who can tell me when made .  Going together AGAIN  .  Polish crank , new rod bearings, different oil line routing , and some aero  (air flow past car) changes .  Belly pan all the way to back of body , blocked off inside grill ( Turbo heat exchanger there ) no radiator , water tank behind driver seat , and have water / methanol injection for engine ,(70 degrees F. in intake going in ports .   STEVE
<p><br></p>
