31-03-2019, 09:57 PM
Hello all,
I'm new to Austin Seven Friends and need some help. I have what I am told is a 1938 Austin Seven Ute (Utility). I bought this car when I was in Australia. The coachwork is from a company called TJ Richards & Sons in Australia.
![[Image: 1938%20Austin.png]](http://nott.link/vehicles/images/vehicles/1938%20Austin.png)
Sadly, when I first brought it home I had some work done to the engine and the "mechanic" replaced the petrol (fuel) pump with a 6 volt electric pump. Also, he lost the original mechanical pump. Unfortunately, he also changed the electric system to negative ground - but putting that right is a project for future. I was pretty unhappy.
I am searching for a petrol pump. Not sure where to begin. I am told that some pumps will fit but that the actuator arm needs to be correct or it can do some damage.
I would be very appreciative if someone can assist or point me in the right direction for the correct pump. I can take photos of the engine block and blanked hole for the pump if need be.
Thank you in advance!
Graham
Graham
