Car type:
17-08-2018, 09:18 AM
(This post was last modified: 17-08-2018, 09:22 AM by JonE.)
My oil button isn't popping out though engine seems healthy and sounds ok!
What is my diagnosis route? - do I start off with rodding the jets, or just look for breached membrane and find some bacon box wrapping? Or just bang it in a particular place if it hasnt been used for 20 years?
Car type:
Thanks. ok. that will be my first check tomorrow! (it's a mkII button)
It doesn't hert to check the jets.
ButĀ First thing is to fit a proper oil gauge, only needs to be temporary. So you can check what oil pressures you are getting.
Then you will know if the button is at falt.
Tony.
Car type:
good plan. I think as mine is largely remade from the chassis rails up, it probably deserves a permanent gauge perhaps - so I have something else to entertain passengers with.
