If it were snowing...
#21
(22-12-2025, 01:53 PM)Mike Costigan Wrote: That was the following (icy) year, Tony, when you tried to squeeze through a gap between the bank and a sideways Arthur Jeddere-Fisher's Vauxhall 30/98. That was the year I failed to finish eating a Mars Bar, it was still frozen solid after hours of rallying  Smile
Thanks, Mike, as ever, correct! Frozen Mars Bars - I had a similar and nearly tooth-breaking experience when I took one out of the elasticated pocket against the side of a glider's cockpit, only to find it frozen solid. On the next flight, I kept it on me, in a warm place....
(22-12-2025, 08:21 PM)Dave Wortley Wrote: Aye lad, it were reight bad then. Awny way tha cud get dahn tu’t pub were on’t wall tops.
That was 1978 and it was true.
Reckless can translate if necessary.
You can laugh at this, but back in the early weeks of 1947 my father organised a trial for the North Midland Motor Club. Between setting the course out and the day of the event the great thaw occurred... half the sections planned were going over walls and other obstacles!
(22-12-2025, 02:38 PM)Steve Bryant Wrote: One car I owned that didn't fair well on snowy roads was my Messerschmidt KR200. The heater was ok once up to temperature but the problem was that the rear wheel couldn't decide which wheel groove in the snow it was going to travel in. If it did track in the center the ride was rough and traction was iffy.
It was a fun car in the summer though. It was replaced by my Austin Seven - I saw the light!
Cheers,
Stephen
Lovers' Lane - the Brockbank Cartoon
