05-04-2019, 09:54 AM
Morning all,
What size 'O' ring do i need to help prevent excessive oil / pressure loss on the front camshaft bearing on a pressure fed engine i am slowly building?
I have read most of the threads, but the actual size is never mentioned.
I have figured out that i need to reduce the size of the oil feed hole in the bearing, but the 'O' ring size and position on the bearing eludes me.
I realise this is a well trodden subject, for that i apologise
