A7 Headlamps
#21
(29-09-2023, 03:35 PM)Hugh Barnes Wrote: With the limited current draw of the LED headlamp bulbs, is there anything to be gained by having an additional sidelight over running on dipped headlights?
Hi Hugh
Probably not but the only time I would use the sidelights is when parking at dusk or night. Not sure I’d want dipped headlights when parked.
Fair enough.. thanks!
