24-03-2022, 07:30 PM
Can any electronic whiz explain the regulators used with pm alternators? Would expect the regulator to interrupt output not short it to earth. Voltage spikes might be a problem but not insurmountable. On a small engine the constant power drain must be significant. Most bikes now run with permanet lights on so the waste dissipation may not be great. I became aware of a few years ago when a colleague cooked his motorcycle alternator and found it common for the make.
