17-11-2019, 09:04 PM
Does anyone have a record of the serial numbers on the back and front wheel bearings , and all the gearbox bearings for a 1934 , 4 speed Austin 7 RP please ?.
Bearing serial numbers
17-11-2019, 10:24 PM
Front Hub Inner: SKF RLS10 (sealed 2RS ), RHP LJ 1 1/4
Front Hub Outer: SKF RLS6 (sealed 2RS), RHP LJ 3/4 Rear Wheel Hub: SKF RLS10 (sealed 2RS ), RHP LJ 1 1/4 (RHP is Ransome Hoffman Pollard using the same numbering as R&M)
26-11-2019, 10:10 PM
Many thanks Tony …. sorry for the late reply !.
