03-04-2019, 04:26 PM
Must feel frightful posh to own a car which doesn't wee oil everywhere it stops...
Flywheel locking tool
03-04-2019, 06:25 PM
Thank you all for the information. The photo makes it clear where and how it is fitted to the flywheel thanks again.
John Mason
03-04-2019, 08:48 PM
HI All,
Before ordering a SPEEDI-SLEEVE the Dia of the shaft needs to be measured accurately because the min & max is only .006 th regardless of sleeve Dia. Also the 99187 that Steve Jones uses is 5/16 narrower than the 99186 this allows the sleeve to Fit better on the shaft they should not be level with the end of the shaft but further on leaving a gap between end of shaft and sleeve and Definitely not Peened over Colin NZ
04-04-2019, 11:15 AM
Ooops - Mine's peened over. I'll deal with it when I get round to assembly.
