15-09-2018, 10:40 PM
Hello people
Anyone know the max rebore size for 3 bearing Ruby ?
Regards
Tim
Regards
Tim
A7 rebore size
Hello people
Anyone know the max rebore size for 3 bearing Ruby ? Regards Tim
16-09-2018, 07:43 AM
Tim,
+0.060 is generally considered a safe bet. If you are lucky they will go to +0.080, but there is variation from block to block and you may break through into the water jacket. They can of course be sleeved. I would suggest checking available piston sizes first, as we now have metric size increments available as well as imperial. Ideally remove no more material than the next available piston oversize, if the bore doesn't clean up then go to the next. So far as I'm aware same is true of all A7 blocks. I would suggest giving the block a good look over for cracks / damaged threads / sheared off studs / blocked cooling jacket (etc.) and address these before spending money on machining.
16-09-2018, 07:47 AM
Thanks Chris
Already bored to +0.060”
16-09-2018, 08:35 AM
