11-02-2022, 01:55 AM
That could well be a possibility Ruairidh.
Rad drain tap hole thread
11-02-2022, 08:52 AM
That is why several of us suggested it to you.
11-02-2022, 02:28 PM
To my knowledge the rad is as made originally so I would have to think that the hole and threads are as originally made also. Probably the best plan of action would be to turn up a thread cleaning tap to match the thread form and TPI and diameter of the drain tap and carefully run that through the hole until the correct fit is achieved.
11-02-2022, 05:54 PM
Nothing is impossible. Radiator and the various cocks could be various threads, including 1/2 UNF. TPI can usually be established with care. A taper tap run through will cut too large for a parallle fitting.
11-02-2022, 06:17 PM
(This post was last modified: 11-02-2022, 06:21 PM by Reckless Rat.)
Have you not got one of these?
Even if it won't fit inside you can take a cast with plasticine or silmilar Photo shows a metric gauge but you'll need an imperial one.
12-02-2022, 02:32 AM
Reckless, thanks for the suggestions. Yes I have several thread gauge sets, but you gave me a great idea about taking an impression from the hole itself so that I can check the TPI then make a cleaning tap to do the honors.
Stephen
12-02-2022, 09:16 AM
and perhaps check that it's the same thread as the drain tap....
12-02-2022, 02:35 PM
I'm hoping it is Hugh.
13-02-2022, 07:53 PM
Another possibility is to use soft wood dowel screwed into the hole to get the thread size/type
13-02-2022, 10:18 PM
I have found it more convenient to count hthreads in say 1/4 inch using the ever handy vernier gauge.
Probably not applicable here but poor threads can sometimes be improved by sawing slots in a bolt, preferably tough stuff, as a tap. From various sources charts are availablae of threads in progressive sizes with tpi/mm pitch, tap sizes etc. Very helpful for identity and for figuring remedies. |
