Three-bearing camshafts
I'm in need of a couple of three-bearing camshafts (the type with the two-piece solid centre bearing) for engines currently under rebuild. On one the shaft is so badly rust-pitted I wouldn't dare use it, and the other, for some reaon, has a mangled oil pump drive gear.
If you can help, let me know how much you would like with postage to Cornwall.
Thanks
Alastair
I've just dug out a couple of 3 bearing camshafts if you're still looking. PM me if you are interested. I'm near Basingstoke.
