His wife is going to be very angry
Not sure how he got two carburettors on a single manifold.
Shouldn't be an air vent in front of the door.
Having read Ivor’s Input can I slightly alter things and say that the door handles are facing the wrong way I.e. the grip part should face forward.
John Mason.
The door has been changed to front-hinged and an extra carb added - but the air vent and tie are in the original picture. There are four other changes; three you might spot - but the fourth is rather dark.
Mr "Shirt and Tie" looks to be no spring chicken. I confidently predict a bad back tomorrow after leaning forward with a lump of cast iron at arm's length !
I guess you've added the foglamp, as it looks identical to the headlamps.
He hasn't got his jacket on!
(24-11-2020, 09:15 PM)Mike Costigan Wrote: I guess you've added the foglamp, as it looks identical to the headlamps.
You're too used to spotting my tricks!
I thought the starting handle went through a hole in the bottom of the radiator grille not the car body.
John Mason
(26-11-2020, 10:13 AM)John Mason Wrote: I thought the starting handle went through a hole in the bottom of the radiator grille not the car body.
John Mason
Good try but, no, that's in the original picture - and altering it convincingly would be quite a job!
Changes include: two bonnet catches instead of one; an extra cut-out on the bulkhead; a mirror on the near-side of the windscreen, extra bolts along the front bumper and a second pair of pliars in the toolbox.....
