His wife is going to be very angry
#21
But have you altered the throttle linkage? As mused upon elsewhere in the forum, is it centre accelerator?
(26-11-2020, 07:28 PM)Steve kay Wrote: But have you altered the throttle linkage? As mused upon elsewhere in the forum, is it centre accelerator?
No, that's as original.
A prudent choice. Otherwise he might be faced with a crank change which would likely prompt overalls. However curing the traditional Morris 8 rear hub oil leak may have threatened his collar.
