Car type: 1934 A7 van
I am restoring my 1937 Ruby,and refitting the instruments and rewiring.I cannot make out how to wire up the original ammeter,as all there is on the back is a strap.
My earlier 7s had 2 terminals for the wiring.
You need to run a loop of wire through the strap to activate the ammeter, don’t ask me which way, I have yet to work that out!
Thanks Ivor.Ive got a wire ,yellow and black from the starter/battery to the ammeter then to the dash light ,and a second wire from the ignition switch to the ammeter
so do i loop one of these through the strap and do i fix it to the ammeter.
Thanks ,so as far as i can make out i join the wire from the starter to the ignition switch and dash light so all 3 are connected and loop one of the wires through the
strap do you wind it round the strap,also fit a fuse on the feed from the starter,is that ok
Thanks Nick thats much clearer i understand now,thanks for your help.
In the previous article, the early ammeter pic shows the 2 terminals bare. They should have covers which consist of an insulating tube with a hole in the side for the connecting wire to reach the terminal. The wire is then secured by tightening top(as in the pic) screw. If you've never seen them my wordy explanation may not be too helpful but unfortunately I don't have a pic.
However you should persevere as there is a risk of a short and consequent fire if they are both left live.
Thanks Nick, busy day yesterday, so didn’t have time to check the wiring, but that makes sense to me, I’ll give it a try.
