08-04-2020, 03:03 AM
(This post was last modified: 08-04-2020, 03:08 AM by Bob Culver.)
Presumably the 2nd gear speed is set by valve bounce which seems to be about these rpm or a tad higher on later engines. They did not see it prudent to mention the brakes.
Car type:
Lovely to see these Tony. Be vigilant for some press record of the first Fabric saloon which had the smaller door design of the R Saloon. So it will be up to two years earlier... we only have a "1927" factory photo.
Interesting to see the scuttle vents appear to be plated, not the usual body colour.
Also the choke having a ring to pull it. I use a length of wash-basin plug chain and a key ring.
Thanks for posting such a good quality scan Tony, my favourite seven and a great read!
