Car type:
Is there a reason that I get continuity not just from both poles to the side earthing surface... but also from pole to pole? (which I thought would be separate circuits)
Happens on two standard bulbs which work fine...
Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
Hadn’t thought about it at all before but it would make sense as they are joined via the earth.
Car type:
ha ha. of course! I can't believe I've been thinking about this all afternoon and hadn't twigged.
So is the reason they maintain separate circuitry in practice because the electrical flow is from the dual entry side, and can't "enter" from the earth, so to speak? Still head scratching a bit...
The common earth in a stop/tail bulb can cause strange effects.
If the lamp at one side has a bad earth then the stop light can earth through the side light circuit to the lamp the other side. This causes the other side side light to come on unexpectedly.
It certainly can.
A single pole bulb fitted in the double socket caused a very mysterious problem on an Austin Seven.
At night with the engine running and side lights and handbrake on the engine wouldn't stop if the ignition was turned off.
The two contacts in the bulb holder were shorted together by the single pole bulb. Thus the handbrake being on was causing the brake lights to be on. The sidelights were feeding the brake lights and hence the ignition. Switching the lights off then caused the engine to stop.
That took Ray Walker in Cambridge a long time to work out!
