Hi
I need to put antifreeze in my ‘37 Ruby and I am also changing the thermostat on a ‘94 Panda so I thought I could use the same on both for simplicity until I got completely bewildered by the variety of antifreeze now available.
I will also( hopefully soon) need the same for a ‘35 Hornet special.
Any Advice ?
I will be at the NEC on Friday( which may just confuse me more!)
Ian
Whatever you choose, do not use OAT antifreeze (organic acid technology) in any of the vehicles you mention. Stick to ethylene-glycol and you should be OK.
I always use Morris MEG antifreeze ( based in Shrewsbury and with a convenient motor factor why would I not??)
I drain and refill every 2 years. I dilute to 33% MEG to water and leave it in all year round.
Right or wrong, mine goes down the sewer!
I suspect the main reason for periodic replacement is that the corrosion inhibitor pack is exhausted; so one might re-formulate as a question: would you rather tip away a bit of anti-freeze now and then, or have your engine slowly disintegrate from the inside out? Mind you, I don't use anti-freeze in the first place!
Could we simply put in new rust inhibitors?
