John Barlow used to make and sell the three spoke castings.
Patrick Chaussat at Carcassonne uses a detachable wheel. At Montlhery I sat in his car which has limited body space, being narrow but not a single seater as such. Patrick uses a standard splined wheel with a wing nut in place of the original hexagon type. It would have been very difficult to get in without removing the wheel.
Robert Leigh
Hi Mark
After some clearance problems with a flattish steering
wheel with the dash and windscreen I’ve fitted a deep dished wheel to
the AllAlloyCup, I can get in OK , just, but getting out involves a lot of
manoeuvring as the clearance problem is now transferred to my
Waist and the space between the B post and the steering wheel!!
I may need to lose a few pounds or more accurately inches!!
Regards
Bill G
22-05-2019, 07:42 PM
(This post was last modified: 22-05-2019, 07:59 PM by Mark Atkinson.)
Hi Ruairidh,
Thats brillant thank you, I will give John a call.
Kind regards, Mark.
Hi Robert,
It is possible, but also very difficult to get into my car with the wheel in place, it is even harder to exit, especially in a hurry, which as this is a track car makes a quick release wheel somewhat of a necessity.
I have a design in mind which will keep the original appearance with the levers still in the centre.
Kind regards, Mark.
Hi Bill,
Keep the inches and make the wheel removable! Until I figured out how to make a QR system work on the Austin wheel, I was looking at pictures of Jappic which just like my modern Audi has a flat bottomed steering wheel.
All the best, Mark.
Car type:
so will the levers etc in your planned design be quick release too? Intrigued...
The Pea Green Special (the mini ERA single seater) has a removable wheel.
I'm sure that someone at Wiscombe Park earlier in the month must have taken a photo of the fitting
Charles
Hi Mark
I’m a slow learner and have realised that I
have the option of using the passenger door,
so that’s one problem solved but not for you!
Regards
Bill
