Car type:
I'm trying to fit a later test device to diagnose the oil button on a 1929/30.
But the fittings are different - the later oil gauge has a smaller male connector.
Is there an adaptor sold that someone else has searched for and found, please?
Probably just as cheap and easy to make up another pipe with the later connections Jon.
That should fit the standard oil pipe take-off in the crankcase.
You will need to check the oil gauge you have to be certain about the thread on it.
What are you trying to diagnose with the oil button Jon ?
The button should lift off the seat at about 2-3 psi,half way out about 5 and full out 7-10 if it works.
The Smiths gauges are usually 1/8 bsp with a flat seat,Others could be anything.
Car type:
12-09-2018, 04:31 PM
(This post was last modified: 12-09-2018, 04:39 PM by JonE.)
Hi. Car runs fine. Oil button doesn't "lift", but have removed to check (I'm just getting engine running so need security of knowing its working!) and the spring/suction seems/feels fine.
I've bought two old gauges - one I think a Harcourt like those on austin 7 dashes - and they both appear to be same male connector... which is smaller than the male connector on the block.
I'm a bit confused as the "bigger one" (the one on the A7W website) is referrred to as 1/8 BSP too - is that just the thread itself? I want to know what determines the brass "nut" size!
Car type:
ok, thankyou... but how would one define the photographed one if you you had to explain its spec to someone? How would others classify them as parts?
the O/D of the stud bit, or the Across Flats dimension?
I believe BSP is specified by pipe bore, 1/8" in this case.
The spec can be found on the internet.
