Just picking up on this much earlier thread, I too have been looking for an old hood bag for my Chummy but nothing’s turned up. Can anyone help with a pattern please? I’ll look to get something made.
Chris
I'm not sure whether the same issue affects Chummies, but one of several reasons I never use the hood bag (or indeed the hood) on my Ulster is that it inflates as you drive along, largely blocking any view to the rear. A central strap was installed in an attempt to curb this, but didn't make a lot of difference. I think it's not so much a rush of air getting in at the front opening, as negative pressure above which 'sucks' it upwards. Given several other negatives, it generally resides somewhere in the garage loft space.
I’d like to keep the hood on as it’s so much of the Chummy’s character and it’s how my father always used it; however, I like driving hood-down… then put it up to hold it’s condition once back in the garage.
I completely understand the untidiness and inflation so need a good solution.
Thank you Tony,
It's useful to see the pictures of your hood in it's bag and the modifications you've made. Are you aware of any patterns out there?
I might just have to knuckle down, take some measurements, and sketch my own templates. And that's before I try and pedal-up an old Singer!
Chris
