22-02-2023, 07:31 PM
Raced at Bonneville Salt Flats for 6 years . 37' 3 MAIN CASE MODIFIED FOR 2 MAIN HADLEY CRANK (standard bearings) .. Front lip repaired .. Case to block extra support w/ 2 studs .. ARP studs w/ thread inserts through out .. Gear oil pump (90 #) w/ external filter.. .060 custom forged pistons w/ wedge tops (8-1 compression ratio) w/ Total Seal rings .. Custom cylinder head for piston fit w/ ARP 3/8" studs /washers / 12 point nuts
DSCN2670 - Copy.JPG (Size: 119.24 KB / Downloads: 588)
DSCN2670 - Copy.JPG (Size: 119.24 KB / Downloads: 588) .. Ali large size oil pan .. Custom off center / lightened followers for timing adjust between intake / exhaust .. Adjustable cam gear made from new cam gear .. Ford Zetec stainless oversize tuliped head valves w/ custom springs (45# / 90#) , titanium retainers .. side valve cover has external oiling for valve springs .. Manifold stainless steel set up for TURBO w/ water and oil cooling . Fuel injection at ports .. Flywheel machined for 60 minus 2 notches for deadfire 2 coil Electromotive ignition w control box / wiring and all sensors for computor control of engine systems . Call 520 591 6318 ( Tucson , Az. USA ) for questions or E mail SCAHANDYGUY@GMAIL.COM NO CAM or RODS .. More pics available , STEVE
