Car type: '33 RP, '36 RTC Special, '39 Cambridge Special, '34 Wolseley Hornet Special, '50 Citroen Traction Avant
Thank you Squeak, I am much obliged. While the Joss/Ian remote is very similar to the one I saw, it has sophistication in its simplicity, the pivot being an example, brilliant.
Also a fine example of the use of Lumiweld, which has had its detractors here at countless car and tool shows.
I shall retreat to the workshop and contemplate my scrap bin............I am going now and may be some time!
Hi Jack, sorry I had not responded and thank you Squeak for the links. Jack FYI the Aluminium component of this remote was gas welded, it was not brazed with Lumiweld.
Hi Ian,
Thank you for the correction, I was almost ready to set aside my scepticism and believe in the magic of Lumiweld after all! Whatever it is superlative ali welding and a lovely overall job. Despite the originators lack of a lathe, I suspect it is beyond my skill set and ability level.
