04-12-2021, 05:59 PM
good question Robert, the connecting rod says PDE11
conrod bolt torque
PDE = Phoenix Development Engineering.
04-12-2021, 08:20 PM
Thank you Charles; now it makes sense.
04-12-2021, 08:26 PM
Hi,
To be safe contact Phoenix and ask them. The E on the head of the bolt is a designation that ARP use for that type of bolt head. The reason to contact Phoenix is to get there recommendation regarding applying the torque dry or with lubricant it does make a big difference HADLEY Recommend Dry ARP generally Lubricated Colin NZ
04-12-2021, 09:08 PM
As Charles and others have kindly pointed out I am referring to ARP bolts not regular grade 5/16" big end bolts or other A7 studs/bolts of the same size.
05-12-2021, 12:33 AM
05-12-2021, 03:39 AM
As this topic will come up on search perhaps should extend further. The stress on a conrod bolt is proportional to the revs squared. Non sports models driven as intended seldom reach 4,000 rpm and valve bounce sets in well before 5,000 so the sutuation is very different from 7000 rpm racers.
The 1250cc sv Minx, geared as the Seven, many of which were held at 60 mph, and with long heavy pistons and long stroke have 5/16 bolts tightend to 16 to 20 lbs ft. One problem is that few are now accustomed to regular use of normal spanners. Unless held carefully ratchet drives can easily apply excessive pressure.
05-12-2021, 12:51 PM
Charles
the crankcase is a 10 stud casting from the 90s Thomas |
