24-04-2021, 10:41 AM
I just need to clarify the threaded fittings into and out of my 1935 Ruby's fuel pump body, Are the by chance 1/8th BSP taper ????
Thread fittings into and out of F/pump?
24-04-2021, 01:22 PM
HI
YES 1/8" BSP TAPERED
24-04-2021, 07:35 PM
I though it was BSPP on the fuel pump. 1/4" is the norm on the earlier rear tank cars
Flange seal with fibre washer. I would be suprised if a Ruby was any different from the earlier cars with a rear tank. The oil pressure take of is 1/8" BSPP for comparison. My car is 1/4" BSPP to 5/16" copper pipe. 1933/34
24-04-2021, 08:04 PM
Many cars have been fitted with much later pumps. Without burrowing in the bsaement to check, were these ANF/UNF as postwar zenith carbs?
25-04-2021, 03:59 PM
Cheers guys, looking at a new carb option. will see how it runs after test drive.
