06-10-2019, 07:10 PM
(This post was last modified: 06-10-2019, 07:10 PM by Hedd_Jones.)
be easy enough to cast a silicone mould from an exisiting lense.
Then liberate the bronze thready bit and cast a clear one in resin.
Might be easier to turn one on a lathe from a lump of clear resin however. Then glue in the thread.
Hi Ruairidh
These lenses have a threaded brass insert. I reckon you could
make rubber mould of the red lens , cast it in liquid acrylic, then
Machine the casting and insert the brass part.
Tom used to cast the GE front lamp lenses this way I think.
Regards
Bill G
Thank you for all your suggestions everyone - very helpful.
